Throttle cable adj. for more power on 400ex?
Old May 8, 2000 | 05:52 PM
v6power87's Avatar
Exactly how do you adjust the throttle cable for more power? Does it really help? Thanks.
Old May 9, 2000 | 05:17 AM
azrob's Avatar
Just adjust the slack out of your cable from the throttle end. Make it so that there's about 1/8 inch play before the power comes on.
Old May 9, 2000 | 09:43 AM
EXtreme-'s Avatar
here we go again....Start by removing the black air intake boot on the back side of the carb. Look into the large hole and the choke will be visible. Beyond the choke, work the thumb throttle and you will see the "slide" moving up and down.
At full throttle, the slide should be seated all the way to the top (dissapearing from sight). Take your finger and check for further movement if there is room and adjust the cable at the thumb throttle till the slide remains at the top position at full throttle.
You can bet the ranch that there will be room to raise it on a 2000 model!...probably at least 3\8ths of an inch. Re-install the boot and let her rip.
Old May 10, 2000 | 01:20 AM
v6power87's Avatar
Well guy's, thanks for the info. I did the adjustment today, we will see how it works when my back heals from last weekends crash! Later.
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
skeets44
Jul 17, 2015 01:04 PM
timster911
Jul 13, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
