tether switch question
Old Jun 11, 2003 | 09:33 PM
v700rider's Avatar
Default tether switch question
what color wires do you use to put on a tether switch on a KFX400 which wire is positive and which is ground
Old Jun 12, 2003 | 10:04 AM
hollywood43's Avatar
My buddy just installed one on his Z400. Here's a copy/paste of a How-to that he found over a Z400 forum:
Below is simple install instructions of the ProDesign or similar kill switch:
Pro Design kill switch on a KFX400 or Z400 will hook up as follows: It is not necessary to remove any plastic or do any major wire moving. Squatting on the right side of the bike (brake pedal side) look just behind the radiator. There you will see the coil. It's a small black cylinder. The coil is connected by 2 (two) wires. One is black and is the "pulse wire" and the other wire is black and white. The black wire connecting to the coil will be the closest to you if you are squatting on the right side of the bike and looking toward the bike. The black wire is connected to the coil with a spade connector which pulls from the coil very easily. Use a needle nose pliers to get to it. You have to unhook it so you can work with it. To get to it you have to push gently away some other wires, etc. in the general vicinity. Now, using a small saddle type wire connector Click here -> http://auffarth.com/connector.jpg you take the long wire from the Pro Design Kill Switch and using the saddle type wire connector or similar connector, connect the Pro Design "long wire" to the black pulse wire. Now, the other wire coming from your Pro Design Kill switch (the short one) goes to any available frame bolt on the bike and is your ground wire. Remember to hook the black wire with the spade connector back up to the coil after you have connected/spliced in the long Pro Design wire.
Old Jun 12, 2003 | 02:33 PM
v700rider's Avatar
Thank you for your info hollywood43. I will try to get it on tonight.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Kyle5050
Dec 13, 2019 04:25 AM
user493
Aug 13, 2015 12:54 PM
jayking232003
Jul 23, 2015 05:48 PM
cornermike
Jul 8, 2015 11:44 PM
