delta II V-Force Reeds & jets
Old Jun 11, 2003 | 10:05 PM
fullthrottle's Avatar
Default delta II V-Force Reeds & jets
My friend has the same atv as me and is using the boysen reeds. His instructions say to lower the jet by 2-3 and raise the clip 1. I have the v force reeds and my instruc only says; you may have to change the main jet and nothing about raising the clip. My machine runs better than good but I am sure it can run better. Is it common to lower the main jet and raising the clip when adding on after market reeds? I believe stock jet was 210. I am currenty running a 200 in 65 degree weather.
Old Jun 11, 2003 | 10:59 PM
CED's Avatar
CED
Give it a try ,you may be ok with your jetting the way it is.Just make sure you do some plug checks.Performance wise you may not see much difference but your throttle response will be a bit better.Hope this helps.
Old Jun 11, 2003 | 11:02 PM
NCScrambler's Avatar
I have the Rad Valve and it said you <U>may </U>have to rejet and change clip positions, but in my case I didn't have to. They probably just say that to cover their butt in case someone puts one on and their engine locks up, they can't blame them for it.
Old Jun 11, 2003 | 11:14 PM
So its pretty much a trail and error thing then?
Old Jun 11, 2003 | 11:18 PM
Yep, mods and jetting for them always are. The manufacturer of the part can give you a heads up on what to try, but in every situation, it will be different as all motors and environments are not exactly the same.
Old Jun 11, 2003 | 11:33 PM
I follow you. thanks. Im still new to the game I started quading in 2000 its a blast . Been on mini bikes dirt bikes since 10 years of age. Getting more confident on working on the machine myself.
ReconBayou
Oct 31, 2022 05:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
