Fuel coming out drain tube??
Old Jun 12, 2003 | 12:55 AM
ClutchOlds's Avatar
Default Fuel coming out drain tube??
My friends 02 Raptor we jetted the carbs and when I turned on the fuel, it came out of the drain tube on the right carb. What the hell did we do wrong. Is the float messed or what. I know we didn't touch the float at all. TIA
Old Jun 12, 2003 | 01:08 AM
polarisisthebest's Avatar
I would say that it is your float bowls, but i am not sure, so wait till someone else answers this for you.
Old Jun 12, 2003 | 01:24 AM
XxDumontRaptorxX's Avatar
Did you tighten up the drain screw on the right carb??? Right now my Warrior is doing the same thing with the screw screwed in... i have the carb apart right now. Could be a stuck float, or you put it together wrong... make sure everything in the carb is clean.
Old Jun 12, 2003 | 03:32 AM
dirtrider078's Avatar
clean the carb
Old Jun 12, 2003 | 07:50 AM
Ward660R's Avatar
Yup its your floats, somehow. First try blowing out the needle and seat valve with some air. Then check it with the clear tube method. ( clear tube on an open drain screw held up by your carbs ) If it is higher than the carbs mating surface you might have accidently adjusted the floats. Just read adjust them. Sounds simple enough right.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 12, 2003 | 08:12 AM
ClutchOlds's Avatar
Thanks, I will try the floats and make sure everything is clean.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Mikea1978
Jul 4, 2015 12:37 PM
Shifts
Jul 3, 2015 07:59 AM
