brakes
Old May 9, 2000 | 07:37 PM
blazer's Avatar
how do i bleed the brakes on my 2000 trailblazer there is no pressure at all when i pull the lever. please help me i need to ride
Old May 18, 2000 | 03:36 PM
KawasakiKid's Avatar
Sounds like that wouldn't hurt. Ensure there is fluid in the reservoir. Have you checked to see if it's leaking anywhere?
If you're not familiar with brake bleeding...ensure there is plenty of brake fluid in the reservoir, have someone pump the brake several times and hold it down, meanwhile loosen the brake line (or bleeder screw) that goes into the caliper, you'll get a spirt of air and fluid to come out, tighten it back up, and repeat until you get a solid pedal or pull of the handle. Remember ATV reservoirs are small, so it will only take a few times before it's near empty. You'll need to keep an eye on it and re-fill when necessary.
Hope this helps!
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
