12 tooth sprocket on raptor
Old Jun 12, 2003 | 07:14 PM
shutupholdon's Avatar
Default 12 tooth sprocket on raptor
I'm thinking of dropping down to a 12 tooth sprocket, through what gears will this give me the most gain? I can fairly easily pull up 3rd gear wheelies, I would like to be able to pull up in 3rd and possibly 4th a little easier, does the 12 tooth give extra torque that high up in the gears? Thanks
Old Jun 12, 2003 | 07:22 PM
ChubbyNug's Avatar
I have the 12 tooth on right now and i can pull wheelies up into fourth gear, i just have to pull up a little harder but other than that it is great to have that much torque... First and second gear will be the most gains!!
~NuG~
Old Jun 15, 2003 | 02:02 PM
BigScary's Avatar
You should have no problem getting a 4th gear wheelie with the 12t sprocket............with a little clutch I can do that now..........and I have a 14t...........
you will be able to tell a pretty big difference in the gearing.....it will have much more torque........better watch 1st and 2nd gear when you are accelerating hard or you will end up on your back.........
Old Jun 15, 2003 | 04:04 PM
sixsixT's Avatar
I think a 42 in the rear would be better, a 43 would be the same as a 12 in the front. It's better to put on a larger rear if you have the clearance than to go smaller on the front.
Old Jun 15, 2003 | 05:38 PM
blinddog's Avatar
sixsixt-
i was wondering why adding more teeth to the back would be more benefitial?
i dont really want to wheelie all the time,i'm looking for hillclimbing speed.which do you recommend?
Old Jun 15, 2003 | 06:03 PM
sixsixT's Avatar
A smaller front sprocket will wear out the chain faster and robs a little power because the chain has to go around a smaller diameter.
For hillclimbing and torque you want bigger rear (or smaller front). For top speed and less torque you want a smaller rear (or bigger front).
For tight trails, hills and dunes a 42 or 43 is about right with a 13 front.
bmxatv10
Oct 14, 2022 06:23 PM
buddieboy
Dec 9, 2016 05:50 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
