12 tooth sprocket on raptor
I'm thinking of dropping down to a 12 tooth sprocket, through what gears will this give me the most gain? I can fairly easily pull up 3rd gear wheelies, I would like to be able to pull up in 3rd and possibly 4th a little easier, does the 12 tooth give extra torque that high up in the gears? Thanks
You should have no problem getting a 4th gear wheelie with the 12t sprocket............with a little clutch I can do that now..........and I have a 14t...........
you will be able to tell a pretty big difference in the gearing.....it will have much more torque........better watch 1st and 2nd gear when you are accelerating hard or you will end up on your back.........
A smaller front sprocket will wear out the chain faster and robs a little power because the chain has to go around a smaller diameter.
For hillclimbing and torque you want bigger rear (or smaller front). For top speed and less torque you want a smaller rear (or bigger front).
For tight trails, hills and dunes a 42 or 43 is about right with a 13 front.
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
