compression and rebound adjustments-how to
Old May 9, 2000 | 10:13 PM
racerEX's Avatar
I was wondering if on most tracks you have your compression and rebound set close to or all the way soft or close to or all the way firm. I have a 400ex w/ a stock rear shock. There aren't any real big jumps, just average sized. I want the plushest setting possible without bottoming off every jump. Any suggestions would be appreciated.
Old May 9, 2000 | 10:37 PM
hot_shoe_cv's Avatar
On a 400 ex stock rear shock I believe the only adjustment is for pre-load. I'm not sure but I think the same is true for the stock fronts also. As to pre load, it depends some what on your weight, style, and terrain. Since it is a fairly easy adjustment to make your best bet is to try various settings on the particular terrain in question.
Strangely enough, your Warrior does have rebound adjustment on it's rear shock. I run mine at ten clicks from soft with the TCS shocks in front and it's definitely not an old man's Warrior
Old May 10, 2000 | 03:22 AM
86atc250r's Avatar
Nope, the EX has a fully adjustable rear shock. The fronts are preload only.
You are just going to have to try a few different settings, there's just way too many factors for someone on the internet to tell you how to set it up...
Old May 10, 2000 | 08:58 AM
hondatrx300ex's Avatar
does it have a reservoir?
Old May 10, 2000 | 11:11 AM
86atc250r's Avatar
Yes, the rear has an attached reservoir like a lot of the modern dirtbikes.
Old May 10, 2000 | 10:41 PM
well that's pretty cool.
Old May 14, 2000 | 09:47 PM
fourstroke's Avatar
I'm looking for front shocks on my warrior. How long have you had the TCS shocks and what are they on? I just put a Works Ultracross on the back and works great, but I'm not sure if I want them for the front.
Old May 15, 2000 | 02:16 PM
86atc250r's Avatar
I have TCS on the front of my 400EX. They are a vast improvement over stock. They seem to have very progressive valving, lower as well as adjustible ride height, smoother ride (especially over 45deg cross bumps), and very good resistance to bottoming. They make the very good rear shock of the 400EX seem not so good anymore (so now I have to spend even more money ).
They are custom built to your style, skill, and weight, use Works bodies, they are hard anodized, have adjustible compression reservoirs, use better shim stack valving, are a dual spring "no preload" design, and supposedly don't suffer from the same problem Works does with their bushings.
Some people have said they are comparable to the high dollar custom Axis shocks.
I have had mine now for almost 2 weeks, very happy with them so far.
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
