Blaster underframe probs...
Old May 9, 2000 | 10:40 PM
Daredevil1's Avatar
My blaster has a bunch of dents along the underside of the frame on the bottom under the engine. I know this weakens the frame and was wondering if there is any way to repair these dents along the bottom by replacing that area of the frame(i dont know if this would also weaken the frame further) or by some other means. By the way they are about 1/8th of the way into the frame pipe. I plan to get a skid plate also to help protect it.
Old May 10, 2000 | 05:47 AM
BC_YFS200's Avatar
Don't think they will cause any problems. If you want to fix them. Try slicing a some tubing down the middle and welding it over the bad spots. Or an entire section would be better.
And get a skidplate!!
YFS200
Old May 10, 2000 | 02:20 PM
supertraprecon's Avatar
yes get a nice thick skidplate
Old May 10, 2000 | 08:07 PM
Daredevil1's Avatar
That sounds good about the putting in new tubing but wouldnt it make that area of the frame where the seam is weaker than it already is because of the dents?
Old May 12, 2000 | 06:36 AM
BC_YFS200's Avatar
Your not putting in new tubing, just overlaying new tube over the bad stuff. With a lot of welding, it should hold up fine.
YFS200
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
