Thoughts on adding Hotseat Hypershift Clutch Kit to modded 03 Trail Boss?
My 03 Boss has a White Brothers Slip On Pipe, Jetted (145), K&N with vented box and an EPI Red Primary Spring. It is now fast for a 330. How much more do you think I can get from the hotseatperformance.com Hypershift clutch kit? Please advise.
Hotseatperformancefan, It has plenty of torque. Not looking for more speed exactly - just didn't know what I would gain from the clutch kit.
Thank you for the reply,
Lukester
Lukester
To get full advantage of your pipe, it is best to get a clutch kit, you will notice more performance bottom to mid and may gain some on top-end. The clutch kits sole purpose is to keep the rpm in the power range and if the pipe is made for more top or bottom, then you need to clutch accordingly to get the benefit.
NCScrambler, Thank you for the details. I will call Rick at RCR and find out if my pipe was made for more top or bottom. If a clutch kit will help accordingly, then I will move forward with it. I will ask Rick for his opinion. You have again put me on a path toward a perfomance solution. Thank you all for the replies.
Lukester
Lukester
Frisky2050
Apr 9, 2020 11:19 AM
