Front sprockett loose
Old Jun 13, 2003 | 10:18 PM
hamiscram's Avatar
Default Front sprockett loose
I own a 2002 Scrambler 400x 4x4. The problem is the front sprockett is loose which is causing the chain and the sprockett to wear prematurely. A friend of mine has a trail boss with the same problem. Does anyone have a solution to this problem, I heard it is common. Please help.
Old Jun 13, 2003 | 11:21 PM
modquad's Avatar
It's common. You have to upgrade to a Sunstar (Hot Seat sells them) or Sprocket Specialties sprockets. Make sure to lube up the splines with anti-sieze when you change them out.
Old Jun 15, 2003 | 08:21 AM
PRAIRIETWIN's Avatar
Are you talking about the counter sprocket? ( trans sprocket )
They are loose to self aline with rear sprocket. My '94 400L had 5200 miles with 3 front sprockets in 6 years. Had the crap run out of it.
Old Jun 16, 2003 | 09:55 PM
hamiscram's Avatar
thank you for the advise.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
carolinabomb
Jul 26, 2015 08:40 AM
TLC
Jul 25, 2015 02:24 AM
tporath
Jul 11, 2015 12:31 PM
