do you have to weld rcr midrange pipe on tb?
Old Jun 14, 2003 | 08:13 PM
Lightman02's Avatar
Default do you have to weld rcr midrange pipe on tb?
do you have to weld rcr midrange pipe on tb, because i order one, or does it go rite on the stock header? HELP?!
Old Jun 14, 2003 | 08:57 PM
trailblazerRIDER's Avatar
No you do not have to weld it. It goes right on to your stock head pipe with the stock exhaust springs. Make sure you dont loose the exhaust springs like i did.
~RYNO~
Old Jun 14, 2003 | 09:01 PM
Lukester's Avatar
If it is the White Brothers E Series Slip on then no weld, it will probably be a slip on (hose clamp) pipe. Be sure to add heat reflector tape as to not burn your plastic. Tripple layer it. I'm sure it's a good pipe and it will all be OK. RCR is a good co..
Valder
Nov 28, 2020 07:38 AM
mrtidy
Feb 3, 2016 05:00 PM
bigred20653
Oct 2, 2015 10:05 AM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
