Blaster gas mileage
Old May 10, 2000 | 09:26 PM
2000_blasterboy1's Avatar
I am going on a long trip soon, and I was wondering how many miles too a tank will a stock Blaster go, thanks
Old May 11, 2000 | 10:45 AM
garyc400ex's Avatar
Not sure about the mileage. One thing that will help conserve fuel is just use enough throttle to keep up on the way to where you are going. After you see approximately how much fuel you have used, you may be able to ride a little more aggressive on the way back! Get a grab bar with a fuel container holder. Do you have a buddy (that's going also)with racks? Take along a chain or rope in case of running out of gas with no additional reserves!
Old May 11, 2000 | 10:51 PM
EdSmith's Avatar
I usually get between 50 and 55 per tank (says my speedometer/odometer) depending on terrain.
Old May 12, 2000 | 01:36 PM
Steve10's Avatar
EdSmith,
Would that mileage be based on a long ride where you aren't very aggresive and have a destination? I'm planning a trip with some guys that ride 4X4's and was thinking of installing an odometer to figure my range. Your mileage is better than I would have guessed.
Thanks,
Steve
Old May 13, 2000 | 02:53 PM
(bump)
Old May 14, 2000 | 10:29 PM
EdSmith's Avatar
I don't check the forum as often as I should. I got that mileage doing general semi-aggressive trailriding. If you are going to a destination you wouldn't want to cut it too close. If you ran the machine easy, shortshifted and ran on open trails and firroads you could probably get a little better mileage.
Ahtatu
Sep 28, 2015 12:14 PM
rgjackson
Sep 17, 2015 11:21 AM
nastyblaster100
Sep 13, 2015 01:19 PM
ylomnstr
Sep 10, 2015 11:08 AM
1966F100
Aug 21, 2015 07:10 PM
