how could i add power to a utility quad?
Old Jun 17, 2003 | 12:27 AM
tlchicken5's Avatar
Default how could i add power to a utility quad?
i need to add power to my utility, how could i do it?
Old Jun 17, 2003 | 02:52 AM
OuTtaConTroL's Avatar
Maybe you should try going down one size in your tire size? or you could try a k&n air filter and a jet kit?
Old Jun 17, 2003 | 10:32 AM
01redrecon's Avatar
Well what utility atv do you have?? You can get a high performance exhaust for most atv's and a k&n filter with a jet kit will also give you more power. If ground clearance isn't a problem you could go down a tire size but the would just make it easier to spin them. Also if just a pipe and filter doesn't add enough power then you can always get a big bore kit and cam.
Old Jun 18, 2003 | 03:40 PM
action450s's Avatar
Going down a tire size would change your final drive ratio too and give you less top speed. Go up a tire size and you'll get a little faster top speed, especially if your bike has the power to handle it. If its a smaller engine, the extra weight of larger tires may slow it over all..
Old Jun 18, 2003 | 08:23 PM
CAM650's Avatar
buy a prairie 650.
Old Jun 18, 2003 | 10:12 PM
Polarisman3210's Avatar
I bet Cam650 knows where you can get one too.
Old Jun 19, 2003 | 01:39 PM
DSWOLF's Avatar
buy a quad then think about power..
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
