98-99 grizzly
Old May 10, 2000 | 11:52 PM
warrior4me's Avatar
Can anyone tell me the changes that were made between the 1998 and the 1999 grizzly. I know it is quite a bit lighter, but that is it.
Old May 11, 2000 | 09:32 AM
MARTYWEZ's Avatar
The 98 had an adj. rear shock and steel rims.
The 99 lost the rear adj. and gained some aluminum rims and side plastic. The 99 also has a redesigned hitch and the oil cooler is mounted higher. The 00 is the same as the 99 except for a redesigned air intake for the clutch.
94 Warrior
96 Banshee
99 Grizzly
do not even get me going on the extras......
Old May 11, 2000 | 11:21 PM
BigDogs's Avatar
I also believe they changed the crank shaft to reduce weight also.
Old May 15, 2000 | 10:21 AM
bayougrizz's Avatar
the 00 has adjustable rear suspension as well.
Old May 15, 2000 | 07:15 PM
sledder's Avatar
The 99's have stainless steel control cables, waterproof electrical components that were barrowed from yamaha's water craft and the 99 is about 40 lbs lighter than the 98
Old May 16, 2000 | 09:03 PM
warrior4me's Avatar
Thanks for the info guys.
Old May 17, 2000 | 10:04 AM
yam8's Avatar
Oh ya the 99 - 00 are also faster than the 98. They increased the top end supposely. My 00 will do 60mph no problem, i have had it up to 62 and then i let off because that is quite fast enough for me.
yam8's Avatar
Oh ya the 99 - 00 are also faster than the 98. They increased the top end supposely. My 00 will do 60mph no problem, i have had it up to 62 and then i let off because that is quite fast enough for me. Oh ya have 900km's on it and no problems.
Hear the Growl!
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
rawbdiggity
Sep 7, 2015 12:05 PM
