250R hot rod crank
Old Jun 18, 2003 | 08:21 PM
briboy's Avatar
Default 250R hot rod crank
I am planning on putting and Hot rod crank long rod in my 88 250R but I was told I will have to put a spacer plate and run a 86 style piston is this true why would I need to use a spacer plate when it is a long rod same has stock or is the hot rods longer than stock and why do I have to run an 86 piston could someone help please thanks
Old Jun 18, 2003 | 10:00 PM
Sm0k3d's Avatar
the 1986 250r, did not have a spacer plate. It was a short crank, then in 88-89 they went long rod, I believe the the piston pin (or whatever is located like 2 cm higher on the 88-89's, but im not sure. I dont know why you would use a 86 piston in a long rod kit, but yess you do need that spacer plate or your piston will go threw your head.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
