Predator carb rumor I heard
Old Jun 19, 2003 | 05:48 PM
NJRipper's Avatar
Default Predator carb rumor I heard
Someone told me to cut a couple coils off the spring in my carb. Anyone know if that does anything? Thanks
Old Jun 19, 2003 | 05:54 PM
NCScrambler's Avatar
Your talking about the #2 spring right?? CARB I wouldn't see that it would help anything, but I could be wrong.??
Old Jun 19, 2003 | 06:16 PM
jcal's Avatar
yeah i did that. there are a couple of other things also that go with a kit. seek and you shall find
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 19, 2003 | 06:17 PM
SP700RACER's Avatar
Drill out the two holes on the slide, (one size larger than they are now). cut the spring, and install a 50 pilot jet. Then either modify airbox or run a clamp on filter. It will rev faster, cure's the jetting problem the predator has as the slide opens, and will prevent the slide from droping and causing your engine to cut out over big jumps.
Old Jun 19, 2003 | 06:20 PM
Makes sense to me. I would think it would've slowed down the slide, but wondered why you would want to do that. Now I know. Thanks.
Old Jun 19, 2003 | 07:32 PM
Predator03's Avatar
That is exactly the kind of expert advice alot of us are looking for. Thanks. (uh...you are right, ain't ya?)
Scott
Old Jun 19, 2003 | 07:49 PM
pudjumper's Avatar
The Predator and the DS have the same carb. This topic is being discussed in the Bombardier forum.
http://forums.atvconnection.com/mess...did/346707.cfm
I recently bought a HSR45 for my Baja and it made a huge gain in power...I'm betting that this carb would work good on a Predator.
JMiller
Old Jun 19, 2003 | 08:36 PM
modquad's Avatar
Hey Pud, that's what you call doin' it the right way. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 20, 2003 | 02:44 AM
pudjumper's Avatar
Thanks mod. Predator was 2nd on my list to buy..only because 1st year out. The Pol is a wolf in sheep's clothing as it's always been and that's what draws me to them. Maybe next year another Pol will be sitting in the garage.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 20, 2003 | 10:03 AM
SP700RACER's Avatar
Actually Pud, that carb is a little big for a 500cc engine. But if money is no object, And you want to do it the so called right way, Lectron has a taperbore carb that is being tested that looks really promising. (works even better with methanol).
Predator03, Yes it really works, this mod has been used on Harley's for years. There's nothing new about the technology, just applying old tricks that have worked for years to the Predator.
