400EX stalling when idle
Old Jun 21, 2003 | 12:30 AM
m1ckey78's Avatar
Default 400EX stalling when idle
Hey guys.
I recently installed a White Brother pipe. I also have a K&N filter with no air box. I live at 700feet elevation. My main jet is a 170 DYNO JET KIT and the idle jet is a 42. The Dyno needle has been set at 3rd notch.
After installing pipe and jet kits, when I run for some minutes, then I am having problems staying idle. I am also having better chances of stalling when pushing the throttle from idle to *whatever*... It just dies 3 times out of 4. The screw under carb is set to about 2 1/2 out.
What is wrong?
Old Jun 21, 2003 | 04:41 AM
CrAcKhEaD's Avatar
running rich?
Old Jun 21, 2003 | 12:09 PM
m1ckey78's Avatar
running rich where? idle jet, main jet, needle? screw??
I mean, the main jet seems ok since my WOT response is reall good..
When I start it, it idle just fine, so I guess the IDLE jet is ok too.
It's just when I push the throttle to go from idle to whatever throttle you like.. small push, or hard push, same result..
Old Jun 21, 2003 | 02:44 PM
powerslider's Avatar
Sounds lean on the needle, raise the needle by lowering the clip also you may want to come out more on the fuel screw. Try 3 turns out to see if it helps...
Old Jun 22, 2003 | 10:58 PM
m1ckey78's Avatar
Powerslider, thanx.
The needle was my next move. I'll try that tomorrow.
Old Jun 23, 2003 | 12:52 AM
snowbuster's Avatar
isnt there an idle screw? im use to utilities, not sure its the same on sports. just wondering.
Old Jun 23, 2003 | 08:22 AM
m1ckey78's Avatar
Yes, there is an idle screw which is changing idle speed... do you think i should play with it?
Old Jun 23, 2003 | 01:16 PM
m1ckey78's Avatar
Ok guys, I tried to raise my needle one notch, and it was worse. Idling very badly, and smoke coming out of exaust. So i reverted it back to the 3rd notch. Any other suggestion?
Old Jun 23, 2003 | 02:17 PM
hutchies's Avatar
Do you still have your airbox lid on? I am jetted the same and have a white bros and K&N and mine runs fine. You only jet to a 170 if you remove the airbox lid. And this may sound stupid but did you seat the air/fuel mixture screw before turning it out. You have to screw it all the way in befor you bring it out three turns. I live at 700 ft as well and it recommends three turns out. Hope this helps.
Old Jun 23, 2003 | 07:46 PM
Try leaning it out then, drop the needle to the second groove to see if it improves. I would remove the Dyno jet kit and go with the stock needle and Kehin jets but you'll have to play with it to find the right set up regardless.
