400EX stalling when idle
Old Jun 23, 2003 | 08:24 PM
m1ckey78's Avatar
Default 400EX stalling when idle
hutchies: yes, my lid is off, and I screwed it all the way before unscrewing it.
When I opened the carb, i noticed how exactly the needle was working when I was pushing the throttle. The needle is not moving unless you push it more than 1/8, and The problem can occur betwen 0 and 1/8... My new guess would be the pilot, but i went from 38 to 42 all with same results...
Old Jun 23, 2003 | 10:11 PM
snowbuster's Avatar
Originally posted by: m1ckey78
Yes, there is an idle screw which is changing idle speed... do you think i should play with it?
yes, but make sure you know where it was set to so if things dont work you could set it back to stock, asuming thats how it is right now.
Old Jun 26, 2003 | 12:46 AM
cals400ex's Avatar
what i would do is get three new spark plugs. i would then go put one in and ride at 1/8 throttle or less for several minutes. check the plug color. then go do the same thing for 1/2 throttle. then do the same thing but at full throttle. i have a feeling your main is way too rich. are you running the pro meg headers? i would think you would need like a 158 main but that is just a guess compared to my curtis sparks pipe and jetting.
Old Jun 26, 2003 | 11:04 PM
m1ckey78's Avatar
it's rainning quite a bit here... i'll try to lean my main as soon as i get a chance and let you know
Old Jun 26, 2003 | 11:43 PM
  #15
RoughRider01's Avatar
Too me it sounds like your needle is set too rich or the fuel/ air mixture screw is too rich. I just doubt it would be the main since the main controls 3/8 throttle and up. The first thing i would lean out the air/ fuel screw, make sure your air filter is clean too.
2quiker
Mar 22, 2022 08:36 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
