False neutral 400ex
Old May 12, 2000 | 05:11 PM
SNELL's Avatar
Has anyone ever had the problem of there 400ex hitting a "false neutral" upon upshifting or downshifting? Just wondering if it's me or the quad. Thanks.
Old May 12, 2000 | 06:30 PM
Duner97's Avatar
Do you have a false neutral? then it probably is the quad.
i know what ya mean, it happens sometimes. it happened to my warrior before it had a long visit to the shop. hopefully your wont end up that way.
Old May 16, 2000 | 01:15 AM
2000400EXinLA's Avatar
MY 400ex has false un-neutrals. in other words it says it's not in neutral when it really is.
Old May 16, 2000 | 02:57 AM
JRM's Avatar
JRM
i think he means jumping between gears when upshifting hard... it happens alot on the 1-2 and the 3-4 upshift.. just shift firmly to make sure it goes in all the way
Old May 16, 2000 | 09:48 AM
shaun's Avatar
Mine did the same thing, but it was never a big problem. Sometimes it was simpler to go from second down to neutral instead of first and up. It was in neutral and the light was not on. You get used to it, however it was a pain in the rear when you are shifting from first to second and miss and land in no-gear-land. But he was right, if you shift a little harder you should not have that problem.
Old May 16, 2000 | 09:49 AM
Buckeye400EX's Avatar
Only time I've had that problem is when initially shifting into first gear while stopped. From neutral, light goes out start to take off but it's still in neutral. There's some 'play' in the neutral area. Upshifting has never been a problem though.
2many2ride
Sep 27, 2015 04:35 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
