broken bolt
Old Jul 3, 2003 | 05:02 PM
colive18's Avatar
Default broken bolt
on my dads sporstman 500 he has a broken bolt. It is located on the lower tight rear a-arm in the back. I had to take the tire off to get to it and now i dont know what do do... does that bolt hole o all the way through to an opening so i can just keep threading it untill it is out or do i need an ezout???
Old Jul 3, 2003 | 05:19 PM
DaveMaxx's Avatar
Default broken bolt
Most of those are going to be "Blind" holes, Which means you will need to use an ez-out. You will be able to see the hole from the back if it does go all the way thru. But make sure it is fully threaded, it probably is not!
Old Jul 4, 2003 | 12:38 AM
BigBadScrambler's Avatar
Default broken bolt
You will need to use an ez-out to remove it. Then go to your local hardwear store and replace all of your a-arm bolts with grade 8 bolts and you wont have that problem anymore
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
