brakes and discs
Old Jul 6, 2003 | 12:30 AM
brainpause's Avatar
Default brakes and discs
I was lubing my '00 Trail Boss today, and checking a few other things. I took a front wheel off to inspect the brakes. I turned the wheel without the tire, and it seems that the brake pads are touching the disk a little bit. I think it is happening on the rear too. The wheel would turn about a turn and a half before it would stop. I made sure the brakes weren't locked at the lever at all. Seems to me just a little bit of resistance would be bad, especially in a TB that doesn't have a huge powerband anyway!
Any advice or help?
Larry
Old Jul 7, 2003 | 11:50 PM
brainpause's Avatar
bump...need help.
Old Jul 8, 2003 | 01:34 AM
ProXPredator's Avatar
Hydrolic brakes always touch the disc. When you let go of the brake lever, they will pull away some, but usually always ride on the disc. Be sure to keep the brake itself clean, and a little wd40 where the pads ride inside the brake after cleaning always helps.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
