'02 Rubicon Trans Problem
Old Jul 10, 2003 | 09:38 PM
fastmudder's Avatar
Default '02 Rubicon Trans Problem
I'm having trouble with the transmission on my 2002 Rubicon.
In the D1-D2 mode, the transmission locks up in 5th gear after about 10 minutes of riding.
When this happens, the transmission LED display starts flashing D1 and it wont downshift.
Switching the **** to ESP does nothing...
I have to shut the engine off and restart it and then everything works fine for a few more minutes.
I called the dealership service dept., and they suggested changing the oil... I did that but it still happens..
Anyone have any ideas what might cause this?
Thanks.
Jamie
ps.. It has 365 miles, 53 hours
Old Jul 10, 2003 | 11:40 PM
ThreeWRacer's Avatar
You have to stop mudding fast. LOL sorry I can help you I drive stuff with manual clutches.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 11, 2003 | 03:47 AM
rammy's Avatar
fastmudder,
its more than likely the shifting sensor. a guy i ride w/ has had to put three in his. his has about 2000 mi on it though. another guy i ride w/ only had about 100 mi on his when his went out. ive heard alot of guys having problems w/ that. not saying thats what wrong w/ yours for sure but its pretty close to the same symptoms anyway. just a thought.
Old Jul 11, 2003 | 09:14 AM
fastmudder's Avatar
Thanks.. I'll check into the sensor thingy... If I can find it..lol
Oh and to ThreeWracer...
The rubicon is actually for "slow mudding"...
For "fastmudding", I do this [img]i/expressions/face-icon-small-cool.gif[/img]
Old Jul 11, 2003 | 10:31 AM
OldFarmer's Avatar
Take it to your dealer, they can find out the problem in 5 mins.
Old Jul 11, 2003 | 10:45 AM
You could take it to the dealer but thell charge the crap out of ya.
Old Jul 11, 2003 | 07:20 PM
fastmudder's Avatar
Called the dealer where I bought it, and they had no idea what would cause it... They said "maybe a pinched wire"..
But they would be more than happy to look at it for 63 bucks an hour...[img]i/expressions/face-icon-small-mad.gif[/img]
Called another Honda dealer, and he said he never heard of a Rubicon Trans doing that either.. He suggested looking through a service manual..
From what everyone tells me, the transmission of the Rubicon is bulletproof.. they haven't had any problems like what mine is doing...
Lucky Me...
Old Jul 11, 2003 | 10:11 PM
douglasss's Avatar
How many miles do you have on the machine? Do you have oversize tires? The reason I am asking these questions is because I have seen alot of Rubicons with the centrifical clutch shoes and drum burning up.# 1 reason is from using D2.The other is oversize tires and using high range when you should be using low.
The angle sensor is also a problem.You can check for problem codes by turn the key on and holding down both shift buttons for about 2 seconds and then release,press them together again and release.If there is an error code it will start flashing the problem code. I think the angle sensor is (6) flashes. I would have to check the book on that to be sure. I hope this will help you.
Old Jul 12, 2003 | 10:43 AM
fastmudder's Avatar
365 miles, 53 hours, bone stock...
I'll try what you said to see if it brings up a code...
Old Jul 12, 2003 | 01:58 PM
coors's Avatar
I got a 03 rubi.Had the same problem.It was the angle sensor for the trans.It is located under the exhaust system.Also mine was flooding in reverse when this problem would occur.Hope this helps
