scrambler 400 pipe getting hot
Old Jul 12, 2003 | 11:35 AM
scrambler420's Avatar
Default scrambler 400 pipe getting hot
hi guys im sick of my pipe on my 02 400 getting the plastic shield so hot that it burns my leg when it touch it..the pipe is a fmf is it normal to be getting this hot?and also would a hpd race pipe solve my problems?thanks for the help
Old Jul 12, 2003 | 12:49 PM
2manytoys's Avatar
The only pipes that are really good for polaris is hpd,aaen,rcr and hotseat. You can also get some heat tape and line the back of the heatshield with it. My hpd pipe gets hot but I can still rest my legg on the shield.FMF is a good brand pipe but not really for polaris.
Old Jul 12, 2003 | 04:27 PM
kyxplorer's Avatar
on my modified 400 xplorer is had to install automotive heat shielding because i started melting my plastic after i ported the cylinder in installed a 38mm tmx carb. I pop riveted "header" heat shielding to the plastic by my leg and between the carb and pipe. helped alot.
Old Jul 12, 2003 | 05:25 PM
Bubba297's Avatar
Yeah, the trail pipes increase the expansion chamber right in the worst spot, where your leg is. But that is the only way they can do it. Some header wrap on the pipe along with the heat shield will work great. You can also use some of the chrome looking heat tape too. But that is your only choices with out changing pipes.Bubba
Old Jul 12, 2003 | 07:42 PM
thanks for the help guys..the expansion chamber on the hpd race pipe is all in the front then it comes through next to your leg as a small pipe right?
Old Jul 12, 2003 | 08:31 PM
Purepolaris04's Avatar
i dont think you need a new pipe on my quad i have a piece of plastic that covers up the pipe also the plastic has heat foil on it so it doesn't melt or anything
Old Jul 12, 2003 | 09:06 PM
my atv also has the plastic cover with the foil the pipe gets so damn hot it melts the foil
Old Jul 12, 2003 | 09:53 PM
naturalite's Avatar
I just took off the plastoc shield and now I wear ridding pants. Before when the pipe got real hot it would make my fuel line vaper lock if i sat still for more than a min.
Old Jul 14, 2003 | 09:46 AM
NCScrambler's Avatar
If your pipe is getting really hot, it may be a sign that you are running too lean. It will naturally get hot, but make sure the jetting isn't the cause. If you want to keep the pipe, you can get jet hot coating that will cool it down alot and isn't very expensive.
Old Jul 14, 2003 | 01:08 PM
i dont want the fmf pipe you guys say its not a good pipe for the polaris..i really like the hpd race pipe,and im thinking it will solve the problem,but i dont want to get that untill i get hpd's trail mod..
