Wiring problem
Old Jul 12, 2003 | 04:38 PM
PeterinAZ's Avatar
Default Wiring problem
I'm giving life to a badly wrecked 97 Xplorer. The entire headlight/speedo pod is gone. I've built a small plastic 'dashboard' for the ignition switch, choke and indicator lights because a new pod is expensive. Without a hi-beam headlight, will I have a problem completing a circuit?
Last year I found that a TB400 wouldn't start, even with a new battery, until I replaced all the burned-out bulbs. It had been pull-started for months with a bad battery. Now, with this Xplorer will I have a problem completing the circuit without a headlight? If so, any way to bypass the hi-beam headlight circuit?
Old Jul 12, 2003 | 07:53 PM
scrambler420's Avatar
i dont think there should be any problem and if there is the way to bypass it would be to buy a single beam switch and replace the duel beam one..im just guessing here but it seem right!!
Ragtop
Jun 27, 2015 03:04 AM
FWhitt
Jun 13, 2015 02:22 PM
wildbill59
Jun 9, 2015 02:28 AM
elpayaso
Jun 3, 2015 10:39 AM
elpayaso
May 30, 2015 05:43 PM
