Help won't start!
Old Jul 19, 2003 | 09:45 PM
devildog23's Avatar
Default Help won't start!
I have a 2000 440ex Honda quad. I was riding out in the dones all morning then went to turn it off to talk to a friend then it wouldn't start back up. Normally the key is turned on when in neutral the light will come on, but now it doesn't. I have a good battery. I have no idea what is wrong, please HELP!
Old Jul 19, 2003 | 10:10 PM
TractorPacker's Avatar
Do you have a balloon?
There is a fuse by the battery, take a look and hope that is it. It should have a spare fuse right there.
Old Jul 19, 2003 | 10:14 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Check for a blown fuse first thing!! The starter and lights, including the neutral light are on that circuit. There is a spare fuse in the fuse holder. The EX is prone to pinched wires in the lighting, that will blow a fuse.
One thing people don't realize, is that the bike will PUSH START EVEN WITH THE FUSE BLOWN!! So, just pop the clutch and ride home!
Old Jul 19, 2003 | 10:28 PM
crispy's Avatar
I hope it's in nuetral. it might be sticking in a gear and u might not know it, is it an auto clutch?
Old Jul 19, 2003 | 11:51 PM
Hondaracer3's Avatar
I had the same problem with mine. I thought it was the battery but it wasnt. It could be the fuse or it could be the cillinoid.
Old Jul 20, 2003 | 01:07 AM
devildog23's Avatar
I have looked at the fuse when i was in the dunes and the fuse was good maybe i pulled and looked at the spare and thought it was the correct one thank you this is my first quad this quad has won 15 trophys 2 3rd place and 2nd the last one is a division so it has a little wear and tear on it and i am a Marine as a Lance Corpral and have a family so I dont have alot of money so i am not looking to spend alot of money so maybe I did check the wrong one thank you
Old Jul 20, 2003 | 01:28 AM
devildog23's Avatar
I have checked for a fuse but maybe i looked at the spare but why did it blow I dont know if there is a short because there is no broken wire anywhere please help
Old Jul 20, 2003 | 01:38 AM
devildog23's Avatar
It is not in neutral it is not an auto clucth so i dont know what is wrong this is my 1st quad
Old Jul 20, 2003 | 01:44 AM
devildog23's Avatar
I have looked at the fuse but it might be the cilliniod if that is how you spell it i will test it
Old Jul 20, 2003 | 01:46 AM
Will it start and run if you push/pull start it?
