88 fourtrax front driveshaft problem???
Old Jul 20, 2003 | 01:19 AM
88fourtrax's Avatar
Default 88 fourtrax front driveshaft problem???
I have a 1988 4-wheeldrive fourtrax. I think I am having problems with the front drive shaft/differential. When the machine is in neutral and the tires are straight you can push it just fine. If the tires are turned at all the differential doesn't seem to be working and the tires grab the ground. I try to push it out of my garage at an angle and it leaves skid marks from the front tires. Also, when you are driving and you turn either way you can hear some noise coming from the front right tire area. When you are going down blacktop about 10 to 15 miles per hour the machine will periodically lerch like the front tires are traveling at a different speed than the rear tires and the slow set has to catch up. I bought it used and did notice that the drive axle boot was slightly torqued out of position. Any ideas on what may be causing this??? If so, what do I have to replace to fix it???
Thanks!
Old Jul 20, 2003 | 12:19 PM
powerslider's Avatar
Check the tire size first, the fronts are smaller diameter than the rear stock. If they're all the same size it won't work as the front drive is geared differently than the rear.
Old Jul 20, 2003 | 02:04 PM
TReX300's Avatar
Sounds like it could be a bad CV joint thats locking up periodicly.
Wooodyii2
Nov 16, 2020 07:14 PM
WilliamBos
Sep 30, 2015 08:08 AM
CanadianViking
Feb 16, 2001 11:56 AM
CountryMiles
Oct 25, 2000 01:03 AM
