Did valve service, now it wont fire, PLEASE HELP
Old Jul 21, 2003 | 05:08 PM
stockbomb's Avatar
Default Did valve service, now it wont fire, PLEASE HELP
I just checked my valve clearances, changed the intake side to the proper clearances, put it back together and it will not fire, it does'nt seem to have spark and I am stumped[img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img][img]i/expressions/face-icon-small-frown.gif[/img]
Old Jul 21, 2003 | 05:12 PM
ThePunisher's Avatar
Did you reconnect your wires? Also did you line up the timing marks correctly at TDC? Are both cams lobes facing 180 degree's from each other, exhaust to the front of the quad and Intake to the rear of the quad?
Old Jul 21, 2003 | 05:18 PM
stockbomb's Avatar
yes I have the marks on the cam gears lined up and the lobes are facing front and back like they are supposed to, I don't remember unhooking any wires?
Old Jul 21, 2003 | 05:22 PM
Did you put the bolt in the crank to keep the piston at TDC? Also what are your valve clearances now? You didn't pull the cams out did you?
Old Jul 21, 2003 | 05:40 PM
stockbomb's Avatar
My valve clearances are .005 all around, I put the TDC bolt in, and I did take the cams out[img]i/expressions/face-icon-small-blush.gif[/img], I have no spark at all for some reason.
Old Jul 21, 2003 | 06:02 PM
biggerisbetter's Avatar
Their are 2 big white connectors that may have come partially un plugged while you were in the process of you maintainance. they are located on top of your engine , just under the gas tank. Also make sure your CDI box was not unplugged, AND also make sure your HANDLE BAR ON/OFF switch is "on".
Bigger.
Old Jul 21, 2003 | 06:26 PM
Hightower's Avatar
there's no deed for embarassment for taking out the cams, I always take out the cams to access the shims, the little bit of added effort is easier than dicking around trying to get them out from under the cams by just lifting them the little bit you can without removing the chain.
If your problem is at all related to your valve adjustment, it has to be what BiggerisBetter refers to. one of those big connectors is from the alternator, the other from the trigger coil at the flywheel it seems like. either can cause the bike to not run, or the cdi box connector. if you truly have no spark, its not related to the cams no matter what position they're in.
Old Jul 21, 2003 | 09:43 PM
stockbomb's Avatar
well I found the problem and it was the smaller of the two plugs above the intake, pushed it tight and VROOOOM[img]i/expressions/face-icon-small-smile.gif[/img], Thanks for the help guys.
Old Jul 21, 2003 | 10:29 PM
SANDMAN430's Avatar
i always pull the cams to do shims, what were you saying to do lift the carrier and try to get them out like that? man what if you dropped a shim in the engine because you didn't have enough room to work[img]i/expressions/face-icon-small-sad.gif[/img] well just checking .
Cole Hadden
Jun 15, 2025 09:05 AM
toonces
Jul 24, 2015 09:03 AM
Captjay
Jul 23, 2015 12:33 PM
95wolv
Jul 17, 2015 08:13 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
