adjusting 300EX suspension
Old Jul 22, 2003 | 02:38 PM
willjoe86's Avatar
Default adjusting 300EX suspension
How easy is it to adjust the suspension on the 300EX, and how is it done?
thanks
Will
Old Jul 22, 2003 | 04:08 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
There is no damping (rebound or compression) adjustment on the 300. Still, the stock settings are pretty good for the average rider.
You CAN adjust PRELOAD (20% sag in front/30% in rear with the rider sitting on the bike in full riding gear). Place the bike on a stand so you unweight the suspension, then just turn the collars. There are notches on the collar. Go to a higher notch to increase preload, and a lower one to decrease. The front is easy to get to, and the back is a real pain!! I have about 5 different shock wrenches, and sometimes I have to use all 5 to get a shock adjusted.
Old Jul 22, 2003 | 07:44 PM
willjoe86's Avatar
how does adjusting the preload affect the performance of the quad?
thanks
Will
Old Jul 22, 2003 | 07:48 PM
GoldenGekko's Avatar
yeah the back is a pain in the but to adjust, i ended up using a falthead screwdriver and a BFH (Big F***in Hammer) adjust the preload will stiffen or soften the springs to adjust for rider weight.....the change in handling is unoticable unless your really picky, when you catch air the shocks wont bottom out as easily on stiffer settings, but the differance is small.
Old Jul 22, 2003 | 10:47 PM
Red Rider
To little preload and the bike will be mushy. To much and it will be stiff. There are some good articles on the net on how to adjust suspension. I will try to find them and post the link.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
