noise in clutch gaurd on 97 scrambler 500 4x4
Old Jul 22, 2003 | 08:44 PM
SCRAMBLERMAN97's Avatar
Default noise in clutch gaurd on 97 scrambler 500 4x4
does anyone have an IDEA what my problem is, ill start it and something sounds like its rubbing up against the clutch, and thyen wen i ride it around for a while it wont sound as bad. does antone have an idea about my problem and wat i mite need, and if its ok to drive it as is. thanx you[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 22, 2003 | 08:54 PM
scrambler420's Avatar
take your cover off and inspect the belt,its probably going bad
Old Jul 22, 2003 | 08:55 PM
2manytoys's Avatar
Sounds like the cover is a little warped and rubbing the clutches. Yes it is ok to drive. The older scramblers had weaker covers and warp easy with heat. They have an upgraded cover with thicker plastic and a drain at the bottom. You can push down,pull up and try to move the cover around to see if it gets worse or better. This will tell you if that is it.
Old Jul 22, 2003 | 09:02 PM
yea when i pull the gaurd back the noise stops. so wat u said is probly rite thanks[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 22, 2003 | 09:06 PM
2manytoys's Avatar
Almost 100% that is the problem. I have heard tons of them.
Old Jul 22, 2003 | 09:08 PM
do u no were i can get one of those thicker gaurds
Old Jul 22, 2003 | 09:10 PM
NUTZ's Avatar
besides upgrading the cover, are you doing alot of slow speed cruising, heavy pulling, climbing etc.. this could be causing the temps to be running high along with improper or worn clutching
Old Jul 22, 2003 | 09:15 PM
the only things i do out of those things u said is climbing.... so wat r u suggesting
Old Jul 22, 2003 | 09:17 PM
BigBadScrambler's Avatar
You have to get the covers at your dealer. You have to replace the inner and outer cover, which are about $90 a piece. It also requires the removal of both clutchs. You may not need a puller for the secondary, but you definately will need one for the primary clutch.
Old Jul 22, 2003 | 09:23 PM
NUTZ's Avatar
HEY, I'M NOT POINTING FINGERS ITS JUST THAT CLIMBING WITH A HIGH RANGE ONLY MACHINE CAN CAUSE SOME HIGHER TEMPS IN THE CLUTCHS RESULTING IN WARPED COVER
