best racing pipe for 300ex
Old May 19, 2000 | 11:01 PM
Man666son's Avatar
i broke it! my cobra exhaust broke today right where the head pipe goes into the connection pipe for the muffler! whats the best racing pipe for a 300ex? i prefer if it uses a 1 1/2 inch head pipe since thats whats on the quad not the stock 1 incher!
and any prices or links to the company would be greatly apriciated!
thankx
Old May 20, 2000 | 01:03 AM
tater300ex's Avatar
I just put on a DG RCM Alloy. I really like it. It has the 1 1/2" head pipe. With a K&N Filter and a 14 tooth front sprocket I can pull a wheelie in 3rd gear where I could not before. That is pretty good considering I am 200 lbs. I got mine on E-Bay used with 1 hour on it in MINT condition for $150.00. You can get one through Dennis Kirk 1-800-328-9280 (CATALOG & ORDER LINE) for $208.99 Part # 44-4466 w/spark arrester or you can get one for $147.99 wothout the spark arrester PN 44-565
Old May 20, 2000 | 01:24 AM
JD250R's Avatar
Call Cobra and tell them what happened. This happened on one of my Mojaves and they told me to send in the old pipe and they would send me a new one. Has broken since, riden it twice as hard to.
Old May 21, 2000 | 09:49 AM
wgnagey's Avatar
If you are racing and or jumping I do not rec. the DG pipe. The aluminum mount brackets do not take the heat and pounding very well. I;ve had mine welded every time I come home from the track. I just ordered the IDS2, the low end on this pipe is not as good as the dg but the mid to high is much better. I'm not saying to make this our choice but don't waste your money on DG. Also DG's head pipe is to long, if you were to cut out four inches at the U - bend you would gain an additional 2000rpm's.But why do that mod when others are already shorter. Let me know what you get.
Old May 21, 2000 | 10:02 AM
Man666son's Avatar
my dad welded a glasspack on to the head pipe. it accually works better than the cobra! low end id good and mid and high is better than the cobra was! i could whellie shifting into 4th gear it never did that w/the cobra, should i stick w/the glasspak or buy a good racing exhaust?
'93 300ex "custom exhuast"
fixin her up for flat-track
mrtidy
Feb 3, 2016 05:00 PM
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
