lightest of everything...
Old Jul 23, 2003 | 04:49 PM
ATVMX's Avatar
Default lightest of everything...
Who makes the lightest....:
Axle
Swingarm
A-Arms
Rims
Sprockets
Handlebars
Bumper
Grab Bar
FootPegs
Frame (anyone?)
Pipe
Nerf Bars
Heel Guards
Steering Stem
Also what different engine components could i get that would lighten up my ds and/ or make it perform better?
thanks alot
Rob
Old Jul 23, 2003 | 07:58 PM
imported_juggalo's Avatar
you can buy titianium bolts to replace all the bolts on the DS and shave off a couple lbs.
Old Jul 23, 2003 | 08:01 PM
dsracer666's Avatar
my rad ti axle saved + - 11lbs
Old Jul 23, 2003 | 08:27 PM
SpinCycle's Avatar
For the price of titanium and carbon fiber you could probably do better by making more HP to carry the weight. For MX I know you want a light machine but with the DS you kinda have to throw that out the window and try to compete with brute force, all the parts that you are looking for will almost all have to be custom except for wheels and such. A titanium axle costs about $1000, you can make lots of HP for that money.
Old Jul 23, 2003 | 08:47 PM
dsracer666's Avatar
I bought one and its worth it if you ride hard! or race
Old Jul 23, 2003 | 10:56 PM
ATVMX's Avatar
what is the wieght of the stock axle?
and does anyone know how much the durablue axle weighs?
thanks
rob
Old Jul 24, 2003 | 12:02 AM
jetjock16's Avatar
if you were in serious need of losing 20-25lbs right now.. for strictly mx racing or something you could run without the battery, headlight, front fenders and brackets, pipe gaurd, heel gaurds, airbox n stuff,...... you get the point.. you could even remove the starter and cover it with a block off plate.... my batt died and was out of the bike, when my friends went ridin i went.. we had to push start it each time.. was a real bisnatch... ill keep the few extra pounds.......... Course this is all much more complecated than just skippin dinner!!!........just throwing around ideas!!
Jetjock16
Old Jul 24, 2003 | 04:58 AM
BillDS650's Avatar
He has made more HP. When you reduce the weight of the drive line more HP goes to the ground and less is need to make the axle turn. The rear shock works better and last longer because it has 11 fewer pounds too control.
Old Jul 24, 2003 | 03:58 PM
TyreSpinner's Avatar
Holy jesus,
Man that stuff is expensive..
Titanium bolts for 1500-1700...it can't be that bad...
Jeff
Old Jul 24, 2003 | 04:07 PM
ATVMX's Avatar
sounds like im going to be spending alot of money.....can anyone tell me how much the stock 02 axle wieghs?
also where can u buy the titanium bolts, brake levers etc...?
thanks
Rob
