'00 325 Trailboss question
Old Jul 23, 2003 | 09:50 PM
Rubidude's Avatar
Default '00 325 Trailboss question
Just bought an '00 Trailboss dirt cheap. It's really not in too bad a shape, but it needs a little work. The main concern I have with it is the clattering sound it makes when starting. Coming from the left side, it sounds like the transmission is rubbing on the plastic cover. Once it idles up, the clattering stops. The previous owner fabricated a patch to cover a hole where it had worn it's way through. Just wanted some info on what is causing it, and what I can do to remedy the situation. This is the first Polaris I have owned, so I'm not real familiar with the setup.
Old Jul 23, 2003 | 11:18 PM
2manytoys's Avatar
You can buy a new cover from polaris. It is either the cover or the clutch masking the noise. Pull the cover off and see if the noise is still there or not. Then you will know what you need to buy!
Old Jul 24, 2003 | 09:00 AM
USMCQuader's Avatar
You can take the cover off and start the quad and observe if anything is 'flopping' around or what not. Wearing through a cover IS NOT normal and should be investigate/ fixed before riding.
Old Jul 24, 2003 | 09:03 AM
USMCQuader's Avatar
Check out this thread. It sounds like your problem ATV Forum thread
Old Jul 24, 2003 | 10:06 AM
Rubidude's Avatar
Seems the clutch cover was the problem. It was warped pretty bad. I got a new one from Surdyke.com for around $65.00. Took care of the problem. Thanks for the info!
What do I need to do to get a little more low end grunt out of it? There's some hesitation when you hit the gas before it engages.
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Myronh
Sep 8, 2015 11:27 AM
