General recoil starter problems
Old Jul 23, 2003 | 11:17 PM
KISSSOFDEATH's Avatar
Default General recoil starter problems
This is a fix for anyone with a recoil starter like on the Kodiak or the P650.
As you may know the rope will not retract sometimes. This is because you have to much friction between the plastic rope housing and the friction plate that holds it all together. If you take the nut and sheild off and install a washer "spacer" between the friction plate and the plastic rope housing all friction will be eliminated.
That nut has to be tight. If it isnt the arm will not come out and turn the crank. If it nut is to tight sometimes the friction is so great the spring that retracts the rope isnt strong enough to over come friction.
Like I said, install a washer between the friction plate and the plastic rope houseing and you will be set. I am 100% sure this will work.
Sjrpp
May 2, 2023 03:59 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
tweeder
Jul 5, 2015 01:57 PM
ranvette
Jul 4, 2015 06:13 PM
