info on warrior
Old Jul 23, 2003 | 11:26 PM
OneWheelWheelie's Avatar
Default info on warrior
I have a 99warrior i have replaced the batterie cylenoid brand new starter what else is gouing to o wrong with it what can go wrong with it should i buy a new one is it a lemon
Old Jul 24, 2003 | 02:16 AM
blindside350's Avatar
Hey i have a 99 warrior too and i haven't had any probs execpt when i left the key on and drained the battery he-he besides that its the most reliable quad i own
Old Jul 24, 2003 | 02:24 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
1wheelwheelie u make absolutly NO SENCE AT ALL!!!
Old Jul 24, 2003 | 04:50 AM
JakalWarrior's Avatar
First things first, does the neutral light come on if your engine is in nuetral and you turn the key?
So you bought a new solenoid and starter but it still wont start huh? Start at the front and move back. First see if it will jump at the starter, if it will, lay a screw driver across the two bolts on top of the solenoid, if it starts there then move back some more. The starter relay is next, take it out and clean it, put it back in and see if it starts, if not, buy a new one I guess. There is a way to test one but I forget how.
First things first though, have you undid all the connectors and relays then cleaned them out? mine wouldnt start one time becase the suckers had to much dirt in em. One even had a spider living in it.
Old Jul 24, 2003 | 08:50 AM
HILLWARRIOR's Avatar
DID YOU CHECK YOUR MUFFLER BEARINGS?
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
