wraping pipes
Old May 20, 2000 | 06:31 PM
Vision's Avatar
have fmf fatty pipes wanting to know where on pipe should wraping be placed to increase mid to top power?also will it make change you can feel on bike or only on dyno?
Old May 20, 2000 | 10:44 PM
blaster18's Avatar
i dont even know what u are talkin about.?
Old May 20, 2000 | 11:42 PM
Vision's Avatar
i read in forum about header wrap being used to retain heat in certain parts of pipe can help with power . i was just interested in what section of pipe if any could help with mid & top power. thanks for any info. 99banshee
Old May 21, 2000 | 09:54 AM
KawasakiKid's Avatar
Vision is talking about header wrap (used in the automotive field). I am completely unaware of the fact of changing the HP/Torque curve by applying wrap. But I can tell you it is a huge help to the engine, by redirecting heat (which steals HP) away from the motor faster. Plus it's easier on the legs.
A 50' roll of exhaust wrap is only $35 so try it. As I mentioned in previous posts, just wrap the pipe (coming from the engine) NOT the entire exhaust (including muffler). You'll use hose clamps to keep it from coming apart. It's REAL simple. Just remember to use gloves, the wrap contains fiberglass, unless of course you like feeling itchy all day? LOL
Hope this helps.
Old May 22, 2000 | 01:39 AM
Backcountry's Avatar
Try experimenting with wrapping the baffle cone. The baffle cone is the cone nearest the end of the expansion chamber.
Pipe components in order from cylinder:
--Head Pipe
--Diffuser cones (most often only 1, but good custom pipes have 3)
--Parallel wall section(belly)
--Baffle cone
--Stinger
Look for the parallel wall section(PWS) which will be near the center of the length of the expansion chamber. The PWS ends and the baffle cone begins, the baffle cone will taper to the diameter of the stinger. Try wrapping the entire section of the baffle cone.
Also try wrapping the head pipe to the beginning of the diffuser cones in addition to the above. It's alot of experimentation each motor and pipe will be different so it makes it extrememly difficult to say how much it may change your pipe's charateristics.
As always CHECK your jetting with each change...
Old May 22, 2000 | 04:09 AM
Vision's Avatar
thanks for info guys. and backcountry thanks for breakdown on pipes very helpfull!
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
