WHAT THE HECK!!
Old Jul 26, 2003 | 11:25 PM
tomasw1's Avatar
Default WHAT THE HECK!!
My predator was making some horrific rear brake sounds. I stopped to take a look and found that my rear axle has a little bit of play. That, and I see new purple colored grease by the axle. The only thing I can think of is that my bearings are shot. I only have about 20 hrs on it so I think it was my fault. I changed to a 39 tooth sprocket and I think I may have over tighten the concentric locking bolts. I have the predator manual and in the chain tension section it says to torque to 45lbs. In the brake section of the book it says to torque the same bolts to 30lbs! Which is right? Am I right in assuming that my bearings are shot if I have play in my axle? Any help would be appreciated. Thanks.
Old Jul 27, 2003 | 12:10 AM
StevieD's Avatar
on my trailboss, if you arent running a hitch, you torque em to 30. if you are runnin a hitch, torque em to 45. i doubt youd run a hitch on a pred, so i dunno
Old Jul 27, 2003 | 12:58 AM
modquad's Avatar
Tomasw, I think I answered you on Predatorowners, about the decal on the side of the swingarm that states 35 ft/lbs. Just to be safe, if you're still in warranty, maybe run past the dealer.
Bleach
1) Engine problems..
16
May 16, 2021 08:23 AM
awheelterd
Feb 2, 2021 06:18 PM
neilbedwell
Nov 10, 2018 11:02 AM
Bratman2
Jul 23, 2015 12:36 PM
bigwave
Jun 30, 2015 11:19 AM
