2012 750i 4x4 actuator help
Old Jun 29, 2015 | 08:34 AM
bigwave's Avatar
From: South Central Illinois, NO where near Chicago, that's not my Illinois
Question 2012 750i 4x4 actuator help
OK, 4x4 quit working, I took actuator off and cleaned up the motor and reinstalled. It worked once then made a clunk and partially sheered off the little square part that fits inside the slider that engages the 4x4. I assume, this happened because I did not align something correctly???? But it fit in and all the bolts fit in correctly so I'm not sure.
2nd, when I look at the new / replacement actuators they are different, they just have a round cylinder and not the square block looking thing that goes into the slide. I felt inside the shaft and turned the wheels and it all still appears to be fine but my actuator is probably toast. Did they change the design of the engagement pin / block?
Does anyone have any idea what the heck I'm talking about ;-)
Old Jun 30, 2015 | 11:13 AM
TLC's Avatar
TLC
This may be a good read Nyroc's ATV info website
Old Jun 30, 2015 | 11:19 AM
bigwave's Avatar
Default How to line up motor on actuator
Can anyone tell me how to line up the motor on the actuator. I took apart and did not get the orientation correct, it partially sheered off the little metal foot. I need some instructions on how to align the magnets and the little foot for re-assembly. I hooked it up to a 12v 10 amp source and the actuator works perfectly, turned on and off a dozen plus times and it worked each time with out fail.
Anyone ???
Njrider1230
Jul 29, 2023 05:16 AM
mark23
Oct 1, 2015 09:57 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
greg74
Sep 10, 2015 07:58 AM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
