Makin a EX faster
Old Jul 28, 2003 | 09:44 PM
Lamar's Avatar
Default Maki na EX faster
What are some good performance parts to make my ex go faster?
Old Jul 28, 2003 | 10:06 PM
witti's Avatar
Default Makin a EX faster
what do you mean go faster? More power, better riding, drag racing, mx?
pipe
air filter(no lid)
cam
carb
big bore kit
susp.
tires
Lamar's Avatar
More Power, more speed?
Old Jul 28, 2003 | 10:26 PM
Lamar's Avatar
SOMEONE HELP!!!
Old Jul 28, 2003 | 10:33 PM
Quadfather's Avatar
Better suspension will allow you to ride faster. If you're looking for the quad itself to go faster, with more power, look into a higher compression piston, a more aggressive cam, and a slip on pipe.
You are looking at quite a bit more money for the suspension. You can get a higher comp piston for around $130, and a cam for about $150. A slip on will run anywhere from $150-$300.
Old Jul 29, 2003 | 12:25 PM
witti's Avatar
my friend has an ex with a pipe, K&N w/no lid, and he just put a cam in it.
The cam makes it pull a lot better through the gears, it keeps reving now instead of leveling off.
The cam wont do as much good without leting the engine breath.
Old Jul 29, 2003 | 12:34 PM
hutchies's Avatar
Pipe, Air Filter (take lid off or drill holes), and rejet the carb. Then start saving up for a new quad or some major engine work.
Pgbama11
Jan 16, 2016 08:19 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Pgbama11
Sep 10, 2015 08:20 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Backwoods_badass
Aug 3, 2015 01:34 AM
