TB Oil Light
Old Jul 29, 2003 | 12:27 PM
CADDIS's Avatar
Default TB Oil Light
My 01 TB Oil light is coming on and the thumb throttle is getting stiff, is it related? Should I maybe take the pump off and clean it? How do I know it is injecting oil?
Thanks
Old Jul 29, 2003 | 11:27 PM
JWtrailblazer250's Avatar
If the oil light comes on that means it needs oil so check it,cap is on the front of the plastic.My thottle cable on my 300 xpress did that too.I just took the cap off of the thottle control and sprayed some wd-40 down the cable and work the thumb thottle thottle a couple of times and came loose.
Old Jul 30, 2003 | 12:15 PM
CADDIS's Avatar
Thanks, but the oil level is full (I'm not that challenged) I was concerned that dirt has worked in somehow and caused the pump to malfunction, which would explain the stiff throttle, the cable seems to be fine, no binding and min friction.
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
