Works Triple Rates Adjustment
Old Jul 29, 2003 | 10:03 PM
Raptor149's Avatar
Default Works Triple Rates Adjustment
I want to make my fronts a little stiffer. How can this be done simply and correctly? Like a fool I somehow lost my adjustment tool, probably by throwing it out w/ the box. Any help would be appreciated.
Old Jul 29, 2003 | 11:02 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It's not clear which kind you have? Mine have a C-clip. You just compress the spring (a spring tool is nice, but you can do it with zip ties if necessary), then move the clip up or down.
Old Jul 31, 2003 | 08:51 PM
Raptor149's Avatar
Honestly i haven't looked at them yet or even ridden them on dirt. Just wanted to check up. Didn't know it was that simple. The spring compression tool is probably what I lost. Thanks.
Old Jul 31, 2003 | 10:21 PM
Red Rider
If you don't have a tool, have someone heavy stand on the front bumper. While the springs are compressed, put several big strong zip ties on the springs to keep them compressed--be careful!! This relieves the tension on the adjuster. Move the clip up or down, then cut the zip ties and check you ride height.
Old Jul 31, 2003 | 10:23 PM
dasheek's Avatar
how much of a difference are your works over the stock shocks? Would you say it was well worth it?
Old Aug 10, 2003 | 08:36 AM
exklr's Avatar
I have works fronts and they are deffinatly worth the money...I haven't run elkas or anything else but for 329 on ebay you can't beat them.
Old Aug 15, 2003 | 04:22 PM
Raptor149's Avatar
So far I've only ridden it in the sand. And compared to last year on the stock shocks, it was a huge difference. The ride was smoother overall, track straighter through whoops, and improved cornering tremendously. Anxiously awaiting my new rear shock and a dry motox track.
Old Aug 17, 2003 | 07:57 PM
havinnoj's Avatar
I have works triple rates on my 250r. I had them valved for a 230lb rider. I am now down to about 190. I know works doesnt adjust to exact weight; they adjust have ranges. I am wondering if I am still in the correct range or if I should have them revalved? Thanks.
BGC
Utility ATVs
Oct 7, 2015 11:50 PM
txkevin
Sep 21, 2015 02:02 PM
cornermike
Jun 3, 2015 07:27 AM
dosthoff
Jan 3, 2000 10:04 PM
Team400EX
Nov 19, 1999 07:21 PM
