Leaking Carbs
Old May 22, 2000 | 01:49 PM
UTBANSHEE's Avatar
I have a 97 Banshee, both of the carbs leak out of the overflow if the gas is left on. I have pulled them apart several times to clean them, but they still leak. Any help would be appreciated.
97 Banshee K&N filters FMF Pipes
'00 400ex
(2) 96 Blasters FMF Pipes
Old May 22, 2000 | 07:41 PM
brandon's Avatar
Take apart the neddle valve circuit and clean it THOROUGHLY. Also check your float levels.
Old May 23, 2000 | 05:28 PM
PamFalcioni's Avatar
Sometimes, the needle and seat (which shuts off the fuel in when the float raises) gets grungy ( like Brandon mentioned), or they get worn.
If you pull them apart, you might be able to see a ridge or pitting on the needle, or the seat (or both!). It won't be real noticeable, but look closely -- even a tiny ridge or a little pitting will allow fuel to leak through.
If you do find pitting or ridges, then replace both the needle and seat.
Old May 24, 2000 | 06:47 AM
millhouse's Avatar
Check you floats for any possible bending. I just had the same problem on my KX500. Fuel would just pour out like crazy. Still check the float valve needle like Brandon and Pam mentioned but keep an eye out for bending too.. Fellow Banshee owner.
Old May 24, 2000 | 09:31 AM
UTBANSHEE's Avatar
Millhouse
Thanks for your response, but what part of the float will bend. Is it the tab that the needle hangs off.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
