Bayou 220 Clutch Adjustment
The clutch is automatically disengaged during shifting. If it does not disengage properly, it may cause hard shifting and possible transmission damage. Adjust the clutch according to the interval listed on the Periodic Maintanance chart.
(every 10 days). 2 Remove the clutch release adjusting screw cover by removing the screws(it's located just below the oil filler cap). 3 Loosen the locknut
4 turn the clutch release adjusting screw clockwise until it becomes hard to turn, then turn the screw back counterclockwise until it becomes hard to turn.
5 tighten the locknut without changing the adjusting screw position.
6 install the adjust cover.
IF ANY OF THIS DOESN'T MAKE SENSE THEN JUST POST ANOTHER REPLY ok thanks.
