wolverine rear brake ?
Old May 23, 2000 | 09:39 AM
Bruce's Avatar
Changed the rear brake pads on my 99 wolverine last night then went for a short ride. When I looked at them there was smoke coming off of them because they were very hot. The pad must be rubbing on the rotor. What did I do wrong? Any suggestions. I replaced the pads with EBC sintered metal pads and they are the correct part for my wolverine.
Bruce
2000 Banshee
99 400ex
99 wolverine
Old May 23, 2000 | 03:49 PM
boomer's Avatar
I put the same pads on my 99 with no problems. If you were able to get the caliper and new brakes onto the rotor, they should be ok. Are all 3 smoking? I always put anti seize compound on the pins in the caliper. Sounds like something may be sticking. Put it up and see if it is dragging.
Old May 25, 2000 | 08:48 AM
Harold's Avatar
Do like Boomer said and also tap the caliper lightly to knock out any mud etc. that might be causing the caliper to stick, also make sure that your parking brake adjustment bolt isn't adjusted wrong.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
timster911
Jul 13, 2015 01:57 PM
