stock front sprocket on honda 300ex
Old Aug 1, 2003 | 10:03 PM
manual's Avatar
Default stock front sprocket on honda 300ex
does anyone know how many teeths the stock honda front sprocket has on the 300ex?
also does anyone know what the back stock tooth sprocket is?
and for track racing should i go lower on bolth of them?
Old Aug 1, 2003 | 10:56 PM
accorracer's Avatar
i think its 13 and 38
as for track racing its up to you but raising the tooth will make for longer gears and lower for shorter
Old Aug 1, 2003 | 10:58 PM
manual's Avatar
yah more top end speed, for the bigger teeth but slower acceleration, and debating if i want more teeth or less teeth, im taking all suggestions
Old Aug 1, 2003 | 11:08 PM
accorracer's Avatar
are there any long straight aways?
i would raise though i think the gearing is too short anyways
Old Aug 1, 2003 | 11:16 PM
manual's Avatar
k ill move the front to 14, and the rear up 1 or 2-does the rear one make a big differnce and do you know if these are hard to replace
Old Aug 2, 2003 | 05:46 PM
accorracer's Avatar
try moving up just one in the front, and its easy to change
Old Aug 2, 2003 | 05:53 PM
manual's Avatar
ok thanks, does back make a big differnce at all?
Old Aug 3, 2003 | 02:29 PM
mahnster's Avatar
going up one on the front has the same effect as going down 3 on the back, going down one on the front = +3 on the back. higher front, lower back will give you more top end but less acceleration. lower front, higher back will give you more accel but lower top speed.
VRRRRT
Jun 27, 2015 09:38 AM
cornermike
Jun 3, 2015 07:27 AM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
lovinhonda
Jan 25, 2000 09:17 PM
