Dune experts please advise !!!!!!!!!
Old Aug 2, 2003 | 09:55 PM
FsT4WrD's Avatar
Default Dune experts please advise !!!!!!!!!
OK , I need honest opinions and answers . First my KFX only has pipe and air mods , 38 hp with hoosers and
29.9 hp with the razr 2's on .... and a 13t sprocket (1 tooth down from stock)
For these hp numbers which inexpensive paddles should I get , I loved how the geckos feel on my friends 416 , but I was smoking him up comp hill Dumont every run , we switched quads and same results mine was smoking his and I had my razr 2's on .
I am not to sure if the geckos were the reason I was smoking him or not . I heard geckos suck and there are
alot better paddles out there . I have riden with them and like them , just wondering if I will smoke him even more if I get geckos or are my razr 2's just that much better against geckos..
I drag about 2 or 3 hours out of a weekend trip , all the rest of the time were playing in bowls and jumping , so side hill stability is a must with my hiding style. My question to you guys is which paddle will be the best for
my hp , gearing , and ride preference (jumping , bowls , 180's , riding along the tops , and light dragging )
I just dont want to spend money on a set of paddles and be slower then I am with the razr 2's
Thanks and every opinion is appreciated ..
Old Aug 3, 2003 | 12:16 AM
RoostItUp's Avatar
I use and LOVE the Skat-Trak Haulers size 20x10x11.5 8 paddle. Those paddle tires are great! They give good control in all situations and good on the pocketbook.
Old Aug 3, 2003 | 12:35 AM
FsT4WrD's Avatar
I am considering Maxxis Roosters V-blade , cause I can get a hell of a deal on them . Money is tight
and 150 is pushing it .
Thanks for the reply bigbubba , I have heard a lot of good things about haulers , I think I would like a
v-blade more then a straight blade do to I almost rolled 4 times today in the sand and 2 of those times
I got to see my KFX from a different angle ......the ground..lol
Old Aug 3, 2003 | 12:45 AM
cpcpatriot's Avatar
I would recomend the gbc sand sharks over the maxxis tires. I used them and they are not as fast as a set of skat-trak haulers but they are close. the gbcs are a durable cheap tire as well. i believe you can get them for under 150 from rockymountainatv. If you like ego racing up big hills at the dunes it is hard to beat skat-traks. I am going back to skat-traks as we speak but if you play ride the gbcs are a great tire. hope that helps dave
Old Aug 3, 2003 | 12:32 PM
WyoDuner's Avatar
Well, you said cheap so GBC or Cheng Shin are your best options. Forget the Geckos - you heard right, they do suck. Roosters seem OK except I've read about them falling apart p[retty fast for a few people.
Old Aug 3, 2003 | 02:04 PM
witti's Avatar
I have sand skate II padles and they work great. I have seen the sand shark padles and they look the same as mine. Might be good ones for you to get.
Old Aug 3, 2003 | 02:08 PM
StillRacinA250r's Avatar
In my opinion, I prefer Haulers. I run 10 paddle on my 250r but would recommend only 8 paddles for your bike. I put my 10 paddle haulers on my modified 400ex and lost alot of HP. I ended up running sand sharks on my 400ex and they worked pretty good and didn't loose that much power. I've since sold the 400ex and the wife rides a Raptor with the same sand sharks. The Raptor (mostly stock) does well with the sharks but plan on installing haulers when she becomes a better rider & I install a few mods. My neighbor runs Geikos. He seems to like them, hasn't had any problems and he runs them on a modified Quadzilla but I think they would put more drag on your bike than a sand shark.
Old Aug 3, 2003 | 07:58 PM
witti's Avatar
I agree haulers are great padles, but they are a lot more than $150. For a quad that only has 30hp and is not serious about draging, a v-padle like sand skateII or sand sharks would work good.
Old Aug 3, 2003 | 10:45 PM
duneittilludie's Avatar
for a cheaper paddle the GBC sand devil would be a good choice but you may want to try to find a good used set of haulers because they are superior in just about every way.i prefer a straight paddle design for serious side hill riding or for railing around a bowl because they dont slide down as easy as an angled paddle.if you are even slightly serious about your drag racing i would stay away from any angled paddle because they will generally make you lose a quad length or two in a 300 foot race give or take a little depending on conditions.
Old Aug 4, 2003 | 11:44 AM
FsT4WrD's Avatar
Thanks guys for the help , I plan on making a purchase this afternoon and most likely will be bidding / buying the sand sharks
