can someone explain a blaster for me?please
Old Aug 6, 2003 | 03:09 PM
yamwarrior101's Avatar
Default can someone explain a blaster for me?please
i thinking of getting one so how diff is it from my warrior....do i have to mix the gas and oil together? how often rebuild? what to rebuild? top end or bottum end? will dealerss do it? how much $$$$$? thanx
Old Aug 6, 2003 | 03:13 PM
TheQuadSport230's Avatar
It's a 6 speed-manual 200CC two stroke quad. You don't have to mix your gas since it has oil injection but people usually remove the injection. I think you should rebuild the top end at least once a week. It's easily moddable but it's less powerful than your warrior stock vs stock.
Old Aug 6, 2003 | 03:17 PM
i'm 14 and don't know anythin about motors rebuild it everyweek? i only ride probably once or twice a week!!
Old Aug 6, 2003 | 03:38 PM
MONSTERQUAD2020's Avatar
it is quite different from the warrior, I think you will like the 2 stroke hard hitting powerband, it is just different from a four's. Stock, you do not have 2 mix the gas becuz of oil injection, but if the injection is removed you will have to. You do not have to rebuild often at all. Especially once a week lol. Maybe once a year or less if you mix it right, you can even mix it a little richer and have to do a rebuild less often. When you do a rebuild you only do the top end usually. Just piston rings and maybe one bore over if needed. Yes dealers will do it but it is very simple to do. If you do the work your self you can buy the top end kit (piston,rings,gaskets) for about $115 or a little more and around here boring the cylinder is $50. So you can rebuild the top end for under 200 easily if you do the work yourself. Well hope I could help good luck with your purchase.
Sorry, I was meaning once a year lol
Old Aug 6, 2003 | 03:43 PM
good
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
