Disconnect A-Arms from Spindles?
Old Aug 7, 2003 | 05:23 PM
Hookandcanman54's Avatar
Default Disconnect A-Arms from Spindles?
I own a Yamaha Warrior and was wondering? How do I disconnect the A-Arms from the spindles? Thank you for your time, John
Old Aug 7, 2003 | 05:29 PM
HoundDog06's Avatar
undo the castle nut from the balljoint and pull it out from the spindle.
~HoundDog
Old Aug 7, 2003 | 05:58 PM
FISHER1648's Avatar
Loosen the castle nut a couple turns (leave it on to protect the threads) then with a hammer hit the cast looking SPINDLE (where the ball joint plugs in) with a HORIZONTAL (not vertical) swing. Do not hit the top of the ball joint/castle nut - you'll mess it up. Striking the spindle "shocks" the spindle and lets it release the ball joint stud. This keeps ya from tearing the boot with a pickle fork. It may take a couple of good square hits to get it to release. Same method for removing the tie rod ends, etc....
Old Aug 7, 2003 | 06:40 PM
Thanks! I assumed that the bolt was somehow threaded through the a-arm, but now I know. Thank you for taking the time out to answer my question. John
exmotocrosser
Sep 13, 2019 06:12 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Jackg17
Sep 26, 2015 09:30 PM
rockinkgin
Sep 25, 2015 01:52 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
