cheap speed!!
Old Aug 7, 2003 | 11:18 PM
BT250racer's Avatar
Default cheap speed!!
i have a 1999 polaris trail blazer all stock excpet for i got a k&n filter and a 12 tooth front sproket. I need the thing to have a higher top speed would anyone know a cheap way of doing it???? and how much faster i will go?? and how much it will cost???
Old Aug 7, 2003 | 11:54 PM
95sport400's Avatar
The only way to go faster is more horsepower. There are not too expensive ways to get there, but nothing you could call "cheap".
Old Aug 13, 2003 | 04:03 AM
2turbo300zx's Avatar
for 160 bucks you can bore your machine over at aaen performance. send your head in and the will port and polish it and give you a .020 piston. considering their pipe is 219 dollars, this is the way to go. and after that bump it up to a .040 over piston. or just send your head in and get it shved and port and polished for like 85 bucks.
Old Aug 13, 2003 | 11:55 AM
BigBadScrambler's Avatar
Shave some weight off. Take off the floor board, oil injection, ect. Anything not neccessary. Also, I heard that race cutting your plastic gives you a few more MPF
Old Aug 13, 2003 | 12:04 PM
NLWarrior01's Avatar
This depends too guys on if his machine is able to rev out as stock .. if it is able to rev out, then changing sprockets can get him more speed. And that's a cheap speed mod. But it will only work if he's able to rev out .. if he can't top out with stock gearing then changing sprockets will only make it worse.
Old Aug 13, 2003 | 12:17 PM
BT250racer's Avatar
if i get it bored do u know how much top speed i will gain??? and what sprokets sizes should i get?? i have 12 on the front and 36 on the back and yes i do rev out and how many moe mph will i gain??
Old Aug 13, 2003 | 12:18 PM
hotseatperformancefan's Avatar
on two strokes you have to send the cylinder to get ported and when you shave the head you get more low end tourqe
Old Aug 13, 2003 | 03:54 PM
AKracer's Avatar
I was thinkin of doin this. Does it make a noticable difference?
Old Aug 13, 2003 | 04:25 PM
still waiten for my head but according to bubba297 it will give it 6-8hp. if you want it done talk to him he knows what he is doing.
Old Aug 13, 2003 | 06:41 PM
AKracer's Avatar
hotseat, how long have u been wating for yours?
