cheap speed!!
Old Aug 13, 2003 | 09:54 PM
hotseatperformancefan's Avatar
Default cheap speed!!
no its not bubbas fault i took it to a place in my area got done today and just took it for a ride. the thing is out of this world. i hit the gas when i was half throttle and the front end started to pull up, not like way up in the air but u could feel it getting light. o im so happy right now but let me tell you need to have a lot of dedication and not loose your temper too easy when compressing the rings to put the cylinder back on.
Old Aug 13, 2003 | 10:31 PM
mudbug04's Avatar
lose ur temper compressing rings?? try buying a piston ring compressor... they are not that expensive.. and prevent u from screwin up ur rings... also.. try the rings in the cylinder before u put it on the piston.. because i learned the hard way.. i was at work and i didnt check the rings in the cylinder and i compressed the rings and got made because they wouldnt go in.. i tapped the piston with a hammer with the compressor on... and the ring broke.. so take er easy... l8r
Old Aug 13, 2003 | 11:22 PM
no i got them on and everything and it runs great one the streat i just gotta test it in the woods tommorow. tell you how it goes.
Old Aug 13, 2003 | 11:44 PM
BT250racer's Avatar
2turbo300zx
(((( for 160 bucks you can bore your machine over at aaen performance. send your head in and the will port and polish it and give you a .020 piston. ))))
but mines 2 stroke i have to get my cyclider ported and my head shaved will it cost the same amout???
and how much top speed will i gain??
Old Aug 13, 2003 | 11:49 PM
  #15
alrite send it to bubba297 but first talk to him i got a good deal from him. it will cost you anywhere from 20-40 to get the head milled .020 . you should be making hp with a pipe, porting, and head milled around 36-38hp from the 22hp stock. i wouldnt get it bored its just not worth the gains you get out of it. but then you want a clutch kit and carb theres another 2-4hp, but when you do that your gonna need a filtercharger which u mite gain 1hp maybe not even. then get into boring it out and lightening the flywheel.
Old Aug 13, 2003 | 11:51 PM
  #16
also have you ever been to traxx motorsports track or majestic trails???
Old Aug 14, 2003 | 12:04 AM
  #17
BT250racer's Avatar
thanks hotseatperformancefan
im gong to look into this soon. and no i havent i just started riding 2 years ago and im hooked i usully just ride around my area we have some awsome places to ride. and theres alot of ppl that rides around here and alot come up from outa state.. have u or any of u ever rode in the hungition / bedord area of PA???
Old Aug 14, 2003 | 12:07 AM
  #18
no but i really wanna go to those places i mentioned and was just wondering if you knew about them. but definetly talk to bubba he knows what he is doing when it comes to engines.
Old Aug 14, 2003 | 12:30 AM
  #19
BT250racer's Avatar
when i get this done, can i still use polaris blue oil and 89 gas or do i half to get higher
Old Aug 14, 2003 | 12:25 PM
  #20
no u will need 93 or 94 gas and i use the gold synthetic but i have used it ever since i bought the quad so i think it would be alright.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
01ssls1
Sep 22, 2015 06:50 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
